On Monday, I picked up my LC at the airport after traveling for work (parked there 5 days) and on my drive home I noticed that my headlights were very slightly flickering, not totally off, just for a half a second they would dim then go bright again. I thought I was seeing things at first, but then it got more noticeable as I got closer to home. I then noticed the center console lights doing the same thing, going dim for a half a second then bright again.
Today is Wednesday and it's doing it more frequently now. I talked to my dad (retired mechanic) and he said it sounds like either the alternator or the serpentine belt going. Serpentine looks fine that I could see. I took it to the local auto place and they tested the battery and alternator. Here's where it's weird, the first test came out at 37v. The guy said that seems low for a car this big but the machine said it checked out "good". I told him to run it again and showed him the lights flickering when the car is running. Second test came in at 51v. Third test came in 37v. Fourth test came in a 44v.
Is my alternator toast? I've never seen anything like this on any car I've owned. I may add, the headlights, dome lights, all lights work fine when the car is off, no flickering. Turn it on and it looks like a light show. Any insight is much appreciated. I might also add that she is idling a little weird, rpm's are dipping ever so slightly when the headlights flicker. The voltage gauge on the cluster is also dipping slightly every time the headlights flicker.
