Interior Lights
Southern California
I was in the process of replacing a driver's side interior light and it went out, I realize all of the interior lights including the dome lights had gone out. Does anyone know which fuse controls the interior lights?
I checked and couldn't find any blow out 10amp fuses, or a dome fuse and the interior lights, garage door openers and alarm (remote controlled door locks) are not working. Any suggestions?
No idea what year you're driving, but the 2000 EWD manual shows the fuse as UZJ100 describes.
The interior fuse panel down by the dead pedal has 3 rows of fuses running front to back. The DOME fuse is all the way to the rear in the middle row. I'd replace it with another fuse and see what happens. If no luck there, post back.
Toyota made a number of wiring changes in the '03 trucks, so if yours is an '03 or later, you'll find the fuse on the passenger-side fuse panel...it should still be marked as "DOME".
hth
Steve
Great feed back, thank you.
I'm driving a 2006 LC. I'll check the passenger side and post again...
Thank you Gents, she's alive with a bright interior. The DOME fuse is exactly as you guys mentioned...
