Instrument Panel and other bulbs
Hi: I have searched and come up with a lot of different responses, so help would be most appreciated. I need to replace bulbs in my 2001 LC. I do not want to go to LED's - want to stay stock!
Need bulb numbers for:
Speedometer/RPM lights
P, R, N, D, L gear indicator lights
2nd gear start, ECT, O/D Off lights
Power mirror switch
Rear quarter glass switches
Center Diff lock button
Hazard Warning button
Second Start mode selector switch
Seat Heater switches
Someone posted a #74, but its not clear what its for! Your help is much appreciated.
Thank you!
I need some insight on this as well. I have a bunch of lights out on the AC display, seat heater lights, AHC lights, etc.
I know you can buy the bulb for the PRNDL at Toyota/Lexus
Subscribed.
I have read conflicting reports that getting access to the back of the dash bezel is either pretty easy, or pretty hard. Not sure which to believe....
I'm tempted to fix my broken "D" indicator with a new factory bulb, but I'm also tempted to either put some tinted mylar in there or somehow use a lower wattage (compatible) bulb so that I'm not blinded by the cluster at night!!! :)
-G
Subscribed.
-G
The only light out in the instrument cluster on this one is the "D", by lack of the other lights on, I know I'm in drive.
I plan to take apart the AC display and determine what bulbs it needs. There is another thread, but it was a Toyota AC display, maybe they call for the same bulbs.
Most people leave the "D" light off, because it's annoying at night (I include myself in that group - I'd rather it was off). The shifter will confirm what gear you're in.
Hope this helps...its a bit confusing, but atleast we know what OEM buls go in teh instrument panel!!
One correction - bulb 90010-01039, I believe, is for the 2nd start/ECT button?
