Instrument Cluster light Issue (2 Viewers)
Ventura County
Hello: Had my landcruiser for 11 months but only took it out at night the other day. When I turned on the head lights, the lights in the dash went out along with the shift selector lights. I also discovered that when the panel lights are on, the dimmer switch does not dim or increase their brightness. I tried searching the internet for anybody with this issue but wasn't successful. I haven't downloaded a wiring schematic yet, but may have to. Has anyone encountered this before?
So which lights exactly work? What is “panel” to you? When you say “the lights in the dash went out…” do you mean that they never lit up, or that that they did light up, and then you observed them fail?
Easier to help if you can clarify above. May be a simple a blown fuse or possibly low-quality LED replacements in the instrument panel.
When I start the vehicle in park at night, all the lights in the cluster(panel) are lit. The moment I turn the lever on the column to turn on the headlights, all the lights in the cluster and my shift console go out. When I deactivate the headlights, the instrument cluster lights come back on.
The fact that the dimmer switch does not do anything seems to be a place to start. Working on or under the dash is not my cup of tea due to a bad back.
I'll see if I can find a wiring schematic.
Thx
John
The cluster is designed to be at full brightness when the headlights are off and dim when they are on, adjustable with the rheostat. The back lighting on the rest of the dash switches should also come on with the lights.
It could be an issue in either the rheostat or the cluster. When you switch the lights on does the backlighting on the switch gear come on? Check mirror controls, rear qtr vent switches, cigar lighter in case one of the bulbs has failed. If yes, it suggests a cluster issue. If no, it suggests a rheostat issue. It could also be wiring either way.
Wiring diagrams can be found with the factory manuals in the FAQ section or they can be found here: LC100 Factory Service Manual - https://lc100e.github.io/index.html
Thanks for replying, sounds like an issue beyond my fixing. Getting that cluster out is not an easy task as I watched a guy replace the led bulb on the Drive indicator.
You asked about the switch gear, not sure what that is unless you are talking about the shifter lights. They go off as well.
Thanks for your response.
Switchgear includes:
Mirror controls, rear qtr vent switches, cigar lighter etc
