Instrument Cluster light Issue
Ventura County
Hello: Had my landcruiser for 11 months but only took it out at night the other day. When I turned on the head lights, the lights in the dash went out along with the shift selector lights. I also discovered that when the panel lights are on, the dimmer switch does not dim or increase their brightness. I tried searching the internet for anybody with this issue but wasn't successful. I haven't downloaded a wiring schematic yet, but may have to. Has anyone encountered this before?
So which lights exactly work? What is “panel” to you? When you say “the lights in the dash went out…” do you mean that they never lit up, or that that they did light up, and then you observed them fail?
Easier to help if you can clarify above. May be a simple a blown fuse or possibly low-quality LED replacements in the instrument panel.
When I start the vehicle in park at night, all the lights in the cluster(panel) are lit. The moment I turn the lever on the column to turn on the headlights, all the lights in the cluster and my shift console go out. When I deactivate the headlights, the instrument cluster lights come back on.
The fact that the dimmer switch does not do anything seems to be a place to start. Working on or under the dash is not my cup of tea due to a bad back.
I'll see if I can find a wiring schematic.
Thx
John
The cluster is designed to be at full brightness when the headlights are off and dim when they are on, adjustable with the rheostat. The back lighting on the rest of the dash switches should also come on with the lights.
It could be an issue in either the rheostat or the cluster. When you switch the lights on does the backlighting on the switch gear come on? Check mirror controls, rear qtr vent switches, cigar lighter in case one of the bulbs has failed. If yes, it suggests a cluster issue. If no, it suggests a rheostat issue. It could also be wiring either way.
Wiring diagrams can be found with the factory manuals in the FAQ section or they can be found here: LC100 Factory Service Manual - https://lc100e.github.io/index.html
Thanks for replying, sounds like an issue beyond my fixing. Getting that cluster out is not an easy task as I watched a guy replace the led bulb on the Drive indicator.
You asked about the switch gear, not sure what that is unless you are talking about the shifter lights. They go off as well.
Thanks for your response.
Switchgear includes:
Mirror controls, rear qtr vent switches, cigar lighter etc
I decided to start by replacing the dimmer switch(rheostat). That turned out to be much harder than one would have thought. I tried finding a new Rheostat, but it turns out there are none in stock anywhere in the world. Hmm, sounds like this is a part that has been a problem for awhile. I got lucky and found a used one in Canada on eBay. Got the rheostat a few days ago, and when I tried it, i had dash lights. I tried my old switch and it was definitely bad. So this morning, decided to put the new switch in, had dash lights but instantly I smelled smoke. Felt the switch and it was warm to the touch, so something inside got smoked. Took the switch apart and found a Mosfet in there that was cracked and darkened from heat. So now I have two bad rheostats. Did some research and found this part discontinued, but there was a substitute part so I ordered two, as I suspect the original switch has a bad Mosfet as well. This part is 25 years old, and I think it just died from old age, and I suspect it was not robust enough to last the life of the cruiser. I think the new part will be a better one. If I get both of them working, I'll do another follow up.
I would check for a short in the illumination circuit. One going bad just as you put it in your truck to replace a dead one is far less likely than something in the truck killing them.
I purchased a used dimmer switch off eBay and when I plugged it in, the dash lights were working. However, the 2nd time I put it in, the mosfet on the pc board burned up. I located some mosfets in China and they are on the way. I think that might fix the problem. Thx for replying!
Follow up. I received the discontinued mosfets for the dimmer switch. I replaced the mosfet and now the dash lights are working when the headlights are turned on. So, it took me a couple of months to get this issue resolved. These parts run hot as there is a heat sink on the pcb, but there was not heatsink paste so that may have resulted in the part failing. Considering they are 25 years old, I feel confident I won't see this problem again.
Hmm, so your original dimmer was burned out, the used replacement you bought also burned out on first use, the evidence for which was scorched mosfet. You concluded mosfets on both dimmers were bad, soldered in new ones, and the problem stopped, yes?
Either you have stumbled on a good side hustle repairing NLA dimmers, or the root cause is still there somewhere in the wiring. Maybe the new mosfets, being new, are just tolerating it better.
My money is on the latter. But if I’m wrong, my money may be going to your future repair business when my dimmer goes.
