Installing an accessory switch
Cairo, Egypt
Hi,
How to replace a switch?
Do I pry out the inner plastic housing or the outer one? or do I need to unscrew the whole lower panel?
You need to remove lower panel first. There's some screws and push clips. See video below. It's for right hand drive, but same process for left hand drive.
Good video. If all you’re doing is replacing a switch you don’t need to unplug every like in the video. You just need access to the bolts.
