I didn’t think it would be worth writing this up initially because there are about a zillion different kits out there and the process likely will be different depending on which one you get. Someone expressed interest though, so I figured it might make a good starting point for someone else’s project.
For the record, I’m starting with a ’92 LJ78 and a completely generic keyless entry kit from Amazon.
There are a lot of wires coming out of the remote control box, but I’m only interested in the following:
▪ Positive and negative 12v wires to power the box
▪ The 6 output wires to the door control. 3 each for the open and close circuits (more on that in a bit)
The rest of the wires I just bundled up and hid behind the unit in case I want to make use of them later.
Powering the remote control box
After you take the driver side door card off, you’ll find the door control box in the lower rear of the door. I tapped into the positive and negative power leads in that harness to power my remote control box. No judgement about what type of tap you use, but the positive wire is blue with a red stripe and the negative is white with a black stripe. Once you’ve supplied power to the remote control box, click the remote a couple of times to make sure you can hear the relays clicking. You’re now done with the easy part.
Connecting the lock/unlock relays
Here’s a diagram of the door locking system:
It’s important to note that the door locking system is triggered with negative voltage, So the output of the remote control box should provide ground to the door switch. Each of the relays in the remote control box has 3 wires:
▪ A normally-closed input wire - terminate this one
▪ A normally-open input wire - connect this one to negative 12 volts
▪ An output wire - tap this one into the wiring for the door switch
Here’s what that looks like:
Don’t tap into the door switch wires too close to the connector or you may interfere with it’s ability to connect to the switch. Trace the wires back toward the harness a bit before tapping in. The Lock wire is red/blue and comes off of position 3 on the connector. The Unlock wire is red/white and comes off of position 4.
That should be it. Check to make sure all of the regular door switches still work when you’re done. Hope this helps. Cheers.
