Installed my Hysteer from marlin
Littleton, Colorado
Now I cant left? don't have full range of motion in both directions. before I started to tear it all off I wanted to see if anyone had any ideas of what could be happening?
Thanks, Max
I thought you had Luke Porters 4x4 Labs steering components?
if it is lukes and you ordered his flat pitman arm it is clocked one key off of center you can cut the big fat spline into two using a hack saw and file. and clock it over one tooth
that is if you are using lukes stuff if not disregard my post
:D
I bought some arms not even thinking that I had fj60 axles with the bigger knuckle pattern.
ended up just buying that whole kit from marlin.
Also, found out that one of the knuckle bearings was binding up and freezing the right wheel from turning. all good now. thanks all!
