Installed keyless entry and remote start on 1996 80 series (1 Viewer)
Richmond, Ky
Guys, I'm new to the board but I'm building an 80 and having a blast with it. Just gonna pass along a little info about keyless and remote start. I researched the factory system for a while and then decided to have best buy install a viper system. I found the 4105 system at the store and they installed keyless and remote start for $199 for parts and labor. Thought that was a good deal, works great!
Nice, I need to look into that
Did you have to remove the factory unit or was this just plug and play?
I'm also running a 4105v and it's not plug-and-play. You can reuse the wiring harness from the factory alarm, but there will be some cutting/splicing involved.
anyone know how difficult it would be to post a guide of this?
i'd love to have a viper installed but don't have a shop i trust not to muck everything up... would love to do it myself...
i wonder if there is a plug and play viper alarm in general
I can post a description of my wiring, but I don't have a schematic right now. You're at a big advantage if your truck has the keyless entry already. The existing system has a removable harness that is quite useful, and it already has a starter kill relay and door lock diodes.
Here are some photos of the completed harness, ignition wires, and door wires. I'll post some diagrams once I can find them.
Completed harness, pre-install: the two white connectors attach to the ignition key switch (old alarm harness). Note the two relays, starter kill and remote start deactivate.
Ignition key switch connector on truck and three wire taps.
Door wiring (note diodes)
