Installed a Redarc brake controller
Houston
I am a big fan of what I call "factory plus" where most of what I do is subtle and not overkill to my gx470. I use my GX470 to tow my lotus elise (~4000lb total with trailer), and wanted/needed to add a trailer brake controller. I loath the bulky traditional controllers that hang down and destroy your shin while driving, and through a little research settled on Redarc.
I bought the liberty controller (~$135), the GX harness (TPH-021 ~$20), and the plug blank (TPSI-007 ~$9). Their harnesses are very high quality, and no additional cost vs splicing your own, and the plug blank fit great! I highly recommend it if anyone is looking. Install was easy, and I just moved the inverter button to right inside the fuse cover if I need it.
1800 miles with zero issues. I do wish the tank was bigger... Trans temps never went over 190 even in very hilly driving. Overall averaged a touch over 12 mpg (calculated). It was honestly very easy to pull, though I have no interest in pulling a tall camper or enclosed trailer.
Thanks for posting, looking into trailer and brake setups. I like Redarc and will go with this most likely but I noticed the harness you posted doesn't have GX470 listed on compatible
>>Toyota suitable Tow-Pro Brake Controller Harness (TPH-021) - https://www.redarcelectronics.com/us/tow-pro-brake-controller-harness-to-suit-toyota-tph-021
Relevant install thread for my reference..looks like it just connects to harness under the steering column
>>Brake controller install help - https://forum.ih8mud.com/threads/brake-controller-install-help.1145681/
If equipped you are correct. I connected the Redarc to the factory harness. Great device.
Roger that, thanks. And it looks like the harness mentioned above was correct. Verified below
TPH-021
Looks like they have a bundle that saves you about $30 bucks. CIKTP-NA-004
Thanks all
