My Hzj79 (1HZ) starts and idles perfect but runs ruff and blows somewhite/blue smoke when the rpm picks up. The plunger lift on the injection pump was at .80mm and I had it reset to spec at GCL fuel systems in Calgary to 1.20mm. It solved the problem temporarily and was running perfect. After about an hour of run time the problem started up again. It gets gradually worse until there is hardly any power. White smoke at high rpm again and little power. Still starts and idles perfect. Resetting the the plunger lift fixed the problem but what could be causing it to go out? Any ideas?
