Posting here as I know that Dan, Marshall and others seem pretty savvy about these 4 pinion FJ80 diffs???
I'm in research mode for my latest build up. Up in the air is what t-case to go with, Orion HD, Atlas or Stak. Orion is a bolt in. The Atlas or Stak would require a centered rear axle. While I have the D60 sitting at Alan's shop (cost to rehab unknown), I was really impressed with the Diamond axle write up for Ben's Raisen from Slee!
Soooo, Ben used the FJ80 four pinion diff due to it having larger bearings that could be machined out for D60 axles. What is a four pinion diff? I know it doesn't have four pinions - so what does that mean? Are the 9" electric locking diffs the only one with the larger main bearings? If not, how do you tell?
Many thanks! Bill.
Many thanks! Bill.
