2000 LC about 178k on the clock
I've got to fix my front brakes so I can get my LC inspected this month. Well... that and the fact that the left front pads have failed and it's now metal on metal. I have to replace one rotor so I decided to buy both front rotors and new pads.
Obviously the left front failed first because I brake with my left foot more than my right foot
With that in mind
I have new axles, new seals, new rack and pinion bushings, and a new rack and pinion. I've been putting off the rack and pinion / axle swap because the procedure outlined in the repair manual sucks. The repair manual says
"NOTICE: Remove the steering wheel assembly before the steering gear removal, because, there is a possibility of breaking of the spiral cable."
I don't want to remove my steering wheel assemble for any reason... ever... You can ask why and the only reason you'll get is that I don't want to. I think it's a s***ty design if you have to remove the steering wheel assembly just to replace the rack and pinion. And I don't believe it's necessary...
If I'm not mistaken I don't have to pull the hubs to install new rotors. But, I need to repack the wheel bearings so I may as well do that while the tires are off.
Since the hubs are going to be off, does it make sense to replace the axles? I already have them. The boots on the CV joints are ripped to shreds and probably have been for a while. So rather than mess with the CV joint replacement thing I just bought the axle assembly.
If I'm going to pull the axles anyway... does it make sense to also tackle the rack and pinion and R&P bushing replacement as well (assuming the manual is full of crap and I don't really have to pull the steering wheel assembly)?
Feel free to opine...
With that in mind
I don't want to remove my steering wheel assemble for any reason... ever... You can ask why and the only reason you'll get is that I don't want to. I think it's a s***ty design if you have to remove the steering wheel assembly just to replace the rack and pinion. And I don't believe it's necessary...If I'm not mistaken I don't have to pull the hubs to install new rotors. But, I need to repack the wheel bearings so I may as well do that while the tires are off.
, this why I ended up removing the column to replace this. So another precaution is when working on the steering make sure the lock is off as it it is a weak point.
