Illuminated Scuff Plates- How Do I Install? And, Driver's Mirror Camera Feed Problem.
Baltimore, MD
2015 LC here. just purchased a drivers door Land Cruiser OEM illuminated scuff plate. However, there are no installation instructions with it. The fit is perfect, but I have no clue what two wires i need to connect so this thing will either illuminated when the vehicle is unlocked (like the dome lights), or illuminate when the door is opened.
Here is the scuff plate connector
I tried to figure this out on my own and tried searching for posts and online help, but was unsuccessful. In fact, i believe in my attempt to figure out what was happening with some wires and connectors, i have now caused my drivers side Multi Terrain camera to now not work..that will now become my 2nd post of today.
I was trying to find the driver's door courtesy light wires at the A Pillar connection because i couldn't fish wires through the rubber gasket/harness that goes from the A-Pillar in the door. This 2015 gasket is shaped flat and doesn't enter the door in the same way my 2007 LX did.
Here is the courtesy light
When i unplugged this white harness connector at the A Pillar, the courtesy light stopped working, so i had assumed the wires from the courtesy light would be found in that connector at i could tap into those. But i was wrong.
Here is the white connector that i unplugged..
In this above pic i Tapped into the pink wire and the black wire, the pink was power, however, the black is where i went wrong. The black wire, (shown in the far right of this pic) is what i think caused the camera feed problem that i now have. And am guessing, when i tapped into it, i disrupted the wire. Now i need to find out how to fix that.
And this is where it connected at the base of the A- Pillar....
So....Questions
1. Does any know exactly which to wires i can tap into in that A Pillar location?
2. This connector that i unplugged, is there a way for me to find out what the wires are that are tied into this connector?
3. Any clue about the Camera feed wire and how to fix?
Thanks in advance, Brian
So you don’t have the connector in the bottom left as pictured? The is toward the rear of the left hand (us driver) door.
Correct, i do not have that pre-installed connector. Mine is a 2015, i thought it was going to be there, but it wasn't.
I did get the illuminated scuff plates installed and working. I needed to connect to the courtesy lights, through the door. I went through the rubber door conduit, and then came out under the flat harness shield. BINGO.
