Ok, tell me if I should mess with the IAC on my LX-450 or not. I have high idle when hot in park or neutral, anywhere from 1200 to 1800 rpm, in drive around 900-1100, both with a/c on. Tapping accelerator pedal may or may not make 100 rpm or so decrease. With a/c off, may or may not decrease whatever the high idle is. When cold, idle is normal, 600-700 with a/c off, 800-900 with a/c on. The throttle body has been cleaned twice in the past few days, once by me and once by a real mechanic.
Seems like the only thing left to check is the IAC valve, by taking it out, inspecting and cleaning it. However, I have been warned by my TLC guru not to mess with the IAC. I know it is only a stepper motor with a plunger, and the likely cause of the high idle is the plunger sticking when hot. Is the plunger plastic? What would cause it to stick?
So, what are my chances of removing, inspecting, testing and cleaning the IAC without breaking anything and making my 450
undrivable??? (I need it to go to the Dayton, OH Hamvention - ham radio convention next weekend.)
Mitch in Mobile, AL
Mitch in Mobile, AL
