Identify this lunchbox locker Please... (1 Viewer)
Tennessee
I've watched vids of several brands but they dont look like this one. I need desperately to get it apart so I can pull the axles...
If anyone has any tips or knows who makes it... Please let me know.
Side note...I do not plan on re-installing it, too much popping and chatter...
Thanks!
Jeff-
Ok, looks like it is a Powertrax No Slip... I believe I can get this finger puzzle apart now!
Thanks guys!!
You need to drive the shaft out to push the inner axles so C clips can be removed. Rotate the carrier to remove the bolt that has pin on the end holding the shaft in place. Unless I'm the shaft has to be removed to allow the inner axles can slip it to release the C clips.
My Lock-Rights have a disc that is used on semi floaters that holds the inner axle out. Once the pinion shaft is removed the disc can move in to C clips line up with the slot used to install and remove them.
Check the manufacturer website for installation instructions. youtube is a great resource as well.
