So I've had it in my head that mounting my winch "foot forward" is a stronger setup than just plopping it down on a horizontal surface...
Agree? No F-ing way? I started thinking about it and now I'm not sure...
Anyways I want to fit this thing between my frame rails and try to keep it up and out of the way.
I have to re-clock the motor and gearbox if I want the feet of the housings facing forward....No problem. So I sit the thing on a jack and push it into place, and the fairlead is going to be way too low.
So I can mount my winch in front of the grill and way higher, but then my bumper will get huge.
Or, I can move the fairlead to the top of the drum instead of the bottom... but I will have to spin the winch around so that the cable is pointed the right direction again. also not a big deal (so what if the stickers are hard to see)
So my main question is will this affect the structural strength of the winch? As long as the mounting pad is forward and the pulling forces are going down through the feet, and not across them in shear, the winch shouldn't care if it's pulling off the top or bottom of the drum, right?? And would that be stronger or weaker than just mounting it horizontal?
