I just spent the weekend putting in a new water temp sensor and a used IAC (from cruiserparts). Once I got everything back together, the idle is way up to around 1800, and there it stays. I tested the new used IAC per the FSM prior to install and the valve seems to turn about 90 degrees for each prong grounded. Is this typical? I expected it would turn more. Further it appeared to be very open; I figured the ECU would just close it. Can anyone tell me if it is operating normal and what I should test next? Thank you!
