IIRC - The plastic gears attached to the motor are what fail and require replacing the whole part. Some have been happy replacing with a fixed antenna similar to a 4runner.
01LXNY -
Did you ever get your antenna fixed? If not, here's some input. Mine had your same symptons - motor not connected to the antenna mast anymore. What's wrong? Coming out the bottom of the antenna mast is a 2-foot plastic cable that gets wound up by the antenna motor. On mine, the plastic cable broke leaving about 10" attached to the antenna. The remainder was left inside the motor assembly. This remainder piece needs to come out to get the new antenna to work.
Advice to you: fix the antenna. Don't substitute a rubber one or a coat hanger. Remember, you own a luxury vehicle. Plus, it's an easy fix.
Parts needed: replacement antenna mast (call around to dealers or CDAN).
Remove the broken antenna mast by removing the "nut" at the base of the antenna (right above the fender). The nut has 4 notches in it to grab with the proper tool, or use one of those rubber lid grabbers from the kitchen wrapped around the nut and gently use some pliers around it. The antenna mast should pull out. You may need to turn on the radio and push the antenna out a bit with the motor.
The FSM doesn't tell how to get to the motor at all. It's hidden inside the wheel well, between the fender and the engine compartment. Inside the wheel well, there is a black plastic "liner" that is held in place by a bunch of plastic push pins and a couple of screws. Remove the ones in the back half of the wheel well. (Don't worry about breaking them, because you probably will. I think I broke about 4 of the 7 I tried to remove. They are a $1 at the dealer to get replacement ones.) You'll also need to remove the screws that hold the plastic liner to the running board, IIRC.
(I forgot to mention - you don't need to remove the front tire if you don't want to. Just crank the wheels fully to the right when you park it to work on it.)
Now, if you gently pull the wheel well liner away, you should see the motor assembly up inside the fender. There is a bolt or 2 to remove and an electrical plug to disconnect. With a little wiggling, the motor should come out. Make sure you hang on to it because the antenna cable will still be attached to the motor assembly. I never removed the antenna cable the whole time I worked in mine.
At the bottom of the motor assembly, there is a black plastic housing, circular in cross section, maybe 4" in diameter. The motor winds up this white plastic cable in here. You need to open this up and remove the old plastic cable. There are a handful of screws to remove (sorry I didn't take pictures). The 2 parts of this housing are held together by a black RTV-type sealant. I didn't remove any of the sealant. Just take off the cover (whichever side comes apart), and look inside for a greasy length of plastic cable coiled up inside. Remove this and re-assemble and re-install and re-connect.
Before putting the wheel well cover/liner back on, make sure you can get your new antenna mast installed. The teeth need to face to the rear of the vehicle. And, you'll probably have to play with the antenna up/down button a few times to get it to work properly.
Hope this helps. (Sorry about the lengthy reply.)
I believe the FM antenna is in the furthest back side window on the passenger side. My deck received FM fine with the mast removed.One thing I can't figure out is why Toyota can't integrate the antenna into the window glass like honda does? You'd think on a $55-70K car, they could do that.
what could possibly be cooler than an adjustable height antenna?![]()
Nothing. Well, maybe sat radio?
