I just installed my new cobra 29 NW classic CB with a 4 ft firestik II antenna and I'm not getting any power to the radio when turned on and plugged in.
BACKGROUND INFO:
Antenna is mounted in back like so...
The 18ft coax running to the center console underneath the carpet along the doors.
I lengthened (heat wrapped) the positive and negative wires (I'm checking the connections to ensure a good current tomorrow). Then I shoved them under the driver seat and up under the foot pedals so I could bring them up to the fuse box. I grounded the negative on the bolt right next to all the fuses (white wire) and then stuck the red positive wire into the cig fuse so that it wont run the battery down while the truck is off.
I plugged in the radio and nothing, it won't turn on.
I'm pretty confident I did everything correctly, but I'm not the best electrician/ mechanic.
Does anyone think they can help determine the problem???
BACKGROUND INFO:
