- Joined
- Sep 17, 2003
- Threads
- 69
- Messages
- 4,620
- Location
- Sunnyvale, CA
- Website
- www.george4wd.taskled.com
Yeah, uneven terrain I can see being a big issue for a top heavy trailer, but I was more looking at the pictures of the OP - basically a reasonable looking dirt road with a few bumps/undulations. Something like that looks like an issue with an oversprung and/or underdamped vehicle/trailer that has no rebound control. i.e. I am thinking of two issues:
1) springs are so stiff that a large bump will cause the trailer to bounce up and potentially over, especially depending on what the ground contour is when it hits dirt again.
2) springs that are soft enough to flex and start oscillating and nothing to dampen that action.
Either could lead to flopping the trailer and can only get worse if top heavy. With a 4wd there's a lot of weight fairly low (chassis, drive train, fuel tank(s) etc). With a trailer most of the weight is much higher, so definitely a higher cog. Add in that in the vehicle you are immediately aware of it getting tippy/bouncy and will hopefully correct the issue immediately, while the trailer is something you only become aware of with the occasional look back in the rearview or when you notice you're dragging it sideways down the track...
Anyhow, just trying to get a feel for the inherent limitations of the suspension system of these generic trailers versus the more modern offroad trailers (and > $$) with independent suspension, shocks and airbags etc.
cheers,
george.
cheers,
george.
