HZJ79 Manual Hubs (1 Viewer)
Tapage
Club 4X4 Panamá
Panamá
Website
www.4x4panama.com
Hello All .. those are new trucks .. but use " auto " front hubs does anyone know a if 80 ( part time with fron manual locking hubs like my lovely Marilu ) series hubs fits in this front diff to replace those factory " auto " hubs .. ?
A pickup like this one ..
thanks !
David
you will have to make the studd holes bigger
Aus can interchange hubs to caps from 105 series awd to 79 series etc
but i think Ishobe had to change more as his truck wasnt Aus spec
i think its 8 mm to 10 mm
But some one else can help out with info but something in my memory bank says ishobie's spec 79 series had to change his CV's to get a longer shaft to stick out for the hub or something.....????
Hi guys, you need the bigger front type hubs - the 80 sieres conversion hubs should work - you will know for sure if the hub isn't round - it has some indented areas in it and a different gasket. You won't need different stud sizes but you will need a different birfield - or atleast check the EPC to see what birfs they used on the auto/manual/fixed type. My full time type with lock out plate birfields were different so I ordered a set from australia.
louis
Thanks Louis .. did you have pics .. ?
This buddy have those factory " automatic " hubs ... though they come with the longer birf .. so maybe hee need the sorters that come in the part time 80 series . ?
