Went for a quick camping trip last night and started noticing a hesitation above 2000 rpm, especially under load (e.g. uphill). Every gear the same. My instinct is air or fuel, so fuel filters will be replaced first tomorrow. Is there anything else that could be causing this that I should look into before I leave again tomorrow?
Detailed description: up to 2000 rpm, very smooth, no matter the load. Above 2000 rpm, starting at about 2200 rpm, there are really small, quick hiccups. RPM stays steady, but the hiccup is both heard (engine tone, ever so briefly) and felt (a small backing away). But the pull then resumes as if uninterrupted. The best way to describe is that it feels like backing off the accelerator very very briefly (almost superhuman short), only I'm not.
What I've checked:
- air filter (clean)
- pressure inside fuel tanks (both fine, lots of altitude changes here but no pressure when opening cap)
- happens on both sub and main tank
- happens on every gear, only above 2000 rpm
- rpm will continue to increase without issue, hiccups possibly more pronounced closer to 3000 rpm
- this is a new issue, and nothing had been worked on or changed in the lead-up to it appearing
Furthermore, I doubt it's the injectors or IP, since engine has 70K km on it. Also, there's no EGR on this 1HZ.
What I've checked:
