Good evening from Rwanda,
I am living in Central Africa since a couple of years and bought a landcruiser HZJ75 troop carrier a couple of months back, 1HZ of course, 1996 model.
The car has spent 300.000 Km on African roads and was fixed / maintained by local garages for her entire life. Meaning: The car was a complete mess when I bought it. But I am spending my weekends working on her and slowly getting somewhere.
But the 4X4 / transfer case is giving me headache big time.
When I bought her, the 4x4 did not work and hadn’t been used for ages. As there were heavier problems with the truck I did not see it as a focus until a couple of weekends back. What I found out since:
There is underpressure coming through the valves to the tubes connected to the Diaphragm Cylinder. After having cleaned it for 5 hours the Cylinder works. Meaning: if I dismount the cylinder from the transfer case and connect the tubes, I can see that the shift link lever moves from left to right according to pressing the 4x4 button in the cockpit. It moves very slowly though. Takes like a 30 seconds to completely move from 2x4 to 4x4 position (how long shall it take?).
But: If I mount the Diaphragm Cylinder to the transfer case it doesn’t move the Front Drive Shift Fork Shaft from 2x4 (meaning shaft in “inner” position) to 4x4 (meaning shaft coming out of the transfer case). If I manually move the shaft, it works and 4x4 engages. But it takes some force to move the Front Drive Shift Fork Shaft manually (hammer and chisel).
As the Diaphragm Cylinder moves very slowly / weak and the Front Drive Shift Fork Shaft doesn’t move easily, I am not surprised that it doesn’t work.
Question: What could be the reason? And what the solution?
Sorry: English is not my mother tongue! Hope you get what I am saying.
BTW: She changes from H to L, so that at least works.
Hope you guys can help!
Cheers
Philipp
Cheers
Philipp
