Hi All!
I just purchased a 1990 HZJ73. It has 135K kms (about 84K miles). The importer changed all the fluids but they used NAPA Gold oil filter, NAPA air filter, and the radiator filter is greenish. Also, the oil looks really dark and thick. They changed the front & rear diff. fluids to 75/90 synthetic.
Other things they did:
Transmission and transfer case fluid changed
Replaced thermostat
New heater and radiator hoses
charged a/c
greased drivelines, ujoints, steering and knuckles
Replaced timing belt, pulley tensioner, and water pump
Replaced Radiator
I'm not familiar with the diesel engine. Should I flush and put Toyota red in? Should I change the oil? If so what should I be using? I use 15W50 for my FJ80 and I'm in Phoenix, AZ. Also should I be changing the filters to OEMs (I use them for the FJ80). They also put NAPA fuel filter in.
Engines is really loud (I know diesels are supposed to be) and there is some exhaust smoke when first started. Is this something I should be concerned about?
The PO also put in own aftermarket steering wheel. Any suggestions on how to get an original?
Thanks for in advance for any suggestions.
Replaced thermostat
charged a/c
Replaced Radiator
