This thread is a spinoff of a Springover thread, but it deserves to be a thread of its own..
hey, I a little birdie told me that you can use marlines hysteer for minipickups on fj60s?
is that true?
Knuckle bolt pattern is the same. Wheel base is different so ackerman steering no longer exists...
is that true?
I am using the whole set up. Be sure, double sure, you tell them it is for a FJ60. The tie rod and drag link are different lengths than a mini, everything else is identical. And, yes their kit uses beefy FJ80 rod ends...
Ackerman angle? Does a lifted, 6000lb. boat handle tight enough to take advantage of Ackerman angle geometry?
Not trying to knock Luke. He does some awesome stuff4x4labs seems to thinks ackerman angle matters - at least they engineered their arms to keep it right.
I've never heard any feedback from anyone running the 4x4labs setup. I know it's more expensive than other options, but does it work noticeably better?
It would be sweet if I could get my 60 to turn as nice as the wife's 80. The 80 feels like it actually wants to make tight turns, where the 60 just wants to go keep going straight.
