hvac troubleshooting (1 Viewer)
185
gc
I had a chance to turn on the hvac system today and I was listening to a electronic whirring noise that sounded like a blend door. Normally my OCD flared up, and I decided to run the HVAC test on the system. The system hvac page came up, all the lights on hvac control panel flashed etc, and finally the numbers 00 illuminated.
I assume that means no problem?
To exit the hvac test mode, pushing the off fan switch should be enough?
Thanks
Thanks
If it 's sounding like a blender, it is either a bad impeller or more likely a small leaf, pine needle or something like that caught in the impeller.
Try using an air nozzle (if you have one) to blow it through the system.
  • Like
Reactions: 185
Same was happening in mine. Unfortunately, it wasn’t a leaf. Fortunately, eBay has decent prices on “junk yard” motors. Easy job too.
  • Like
Reactions: r2m
