hubcentric or lugcentric, my brain hurts from reading about it.
Why not just use Equal or Counteract?
No need to worry about how the the shop balances your rims.
I have been using Counteract http://counteractbalancing.com/ , which is for semi's and big trucks (got it from work). Onec I got the right amount in the tire I have had no problems with the tires shaking even when snow and mud is packed on the tire/wheel
Now Counteract says to use the passenger fromula called Counter Balance.
From what I have read on their last web sit said that it uses static electricty to keep the beeds in place whe you stop.
My mullet tires (wild country rvt mud lug) only had bad wear on the outside lug. I think that may of been from a loose wheel bearing and not rotating them enough.
The tire has so much outside wear that when I have the tire off the vehicle it leans.
I plan on either having the tire rotated on the rim or replace the tires.
I will try the CounterBalance the next time I get new tires.
