Hub flange torque spec (1 Viewer)
north carolina
Is there a specific torque spec for the front hub flange nuts or just tighten it up pretty good? I pulled it off to tighten my wheel bearing. I also have wheel spacers, the torque spec for them is the same as the lugs right? 76 lbs?
Yep.. they are easily over torqued
And for that very reason I set my torque wrench on 22 ft. lbs and have never had a problem.
My TW is calibrated and accurate within 2% but many inexpensive wrenches can be off by quite a bit.
