Awesome thank you - much appreciated. The gel coat is the layer just on top of the fiberglass?
That’s a great illustration, thank you!Just because it was a good picture to illustrate it - the OEM Cygnus'y paint is a slightly more tan color than the gelcoat, so if you watch carefully while sanding you can do pretty well. If you start to see that spotting like near the "gelcoat" arrow, that's another indicator you're getting the gelcoat thin.
Sand through the gelcoat and you'll have some pores to fill - not the end of the world, but good to keep it to a minimum. :-D
hi, the pop rivets are round. any thoughts how to drill them out with out damaging anything?
Checking in for any updates on your FJ40 fiberglass top refurb. My '75 goes into a boat repair shop later this week for their recommendation on top repair and coating. Assume the bright white on mine is an old PO top coat paint with gray primer. It's cracking and flaking off per photos. Is the bone color underneath Cygnus paint? I don't think it's the gel coat...anyone able to confirm? No fibers showing. So Toyota painted the tops after gel coat - correct?
I ended up sanding everything down with 80 grit to fully restore the hard top. Also got a new drip rail and working on that too. Plan is for a high build primer before paint. Trying to decide if I’m going to do the paint work myself.Checking in for any updates on your FJ40 fiberglass top refurb. My '75 goes into a boat repair shop later this week for their recommendation on top repair and coating. Assume the bright white on mine is an old PO top coat paint with gray primer. It's cracking and flaking off per photos. Is the bone color underneath Cygnus paint? I don't think it's the gel coat...anyone able to confirm? No fibers showing. So Toyota painted the tops after gel coat - correct?
Yes look at post #24 above. @zerotreedelta made an illustration of where the gelcoat layer is. I’m sure sanding the top yourself will save you a bunch of money. It took me a few evenings. Also it’s very very messy unless you have a good dust control system (I don’t).Nice work! So is the bone shade material the gel coat? Guess maybe doesn't matter....just avoid grinding into glass - correct? I've seen recommendations using 3M marine high strength repair filler for the short strand filler repairs. Follow up w/ 3M marine premium filler for fine tune. Then high build prime? Will be interesting what the boat repair shop says. I will propose to do most of the sanding if it won't void warranty of their work. Looks like using an electric DA sander works fine.
Look up rivet shavers used on air planes. They shave heads off without damaging roof. Look like these.
