How to post a sale add?
how dose one go about posting an 80 for sale? Classifieds are saying i dont have enough privilege
Whatcha got selling? Post here. Maybe a mod will move it. Could be crazy, but thought at one point you needed 10posts or so to open some doors.
5500 firm. Ithaca ny
1995 fzj80
274k miles
New within last 60 days.
2.5" ome lift.
New bearings, races, seals in rear axle. (Koyo)
New powerstop drilled/slotted rotors
Powerstop ceramic pads
All new oem bushings except for the new castor correction bushings that came with lift.
All new oem ebrake shoes and all new hardware
Bluetooth touchscreen kenwood stereo with all new speakers.
Scan gauge
New level 8 wheels with good k02's (285s)
Cut out a rust spot in bumper and created a hitch. See photos.
Also blasted and painted every part that was removed during lift install. J arms included.
I have yet to be installed;
Marlin crawler full knuckle rebuild kit (koyo)
Oem wiper seals
Power stop drilled/slotted rotors
Oem oil pump cover seal
Oem crank seal
Oem dizzy o ring
Immaculate grey leather interior. No stains, rips, cracks exc.
Weathertech floormats
Comes with a brand new set of ebay pocket flares.
Used set of 1994 fj80 flares
Po swiped a guard rail and wiped out the drivers side flares. I have all but front fender flare. I also have the missing mud flap.
Runs, drives, stops beautifly.
No issues outside the drivers side damage.
Runs all day at a consistent 190°
Very nice truck. Id gotten a new one and want to invest (sink) more money in my crawler t4r.
I would trade for;
5 speed 3rd gen runner with rear locker.
88" or better harley
Complete dual case set up with crossmember and triple sticks for 1st gen 22re/w56 4runner.
Maybe a 60-70s corolla wagon.5500 firm. Ithaca ny
1995 fzj80
274k miles
2.5" ome lift.
Scan gauge
Oem wiper seals
Oem crank seal
Oem dizzy o ring
I would trade for;
Any pics? Sounds like a decent 80. Given location any rust stuff going on?
A little rust. Drivers rocker under rear door being the bad spot. Hasn't gotten into the door jamb. But its definitely a cut out and replace section. I found no bad spots on frame. The only rusty area on frame is behind rear axle. I'd ground down and painted most of it when i made the hitch. Pass side inner fender has a rust hole as well. Almost forgot that one. Per carfax it was in n.carolina until 2016 when it came to ny. Ill see if i can get some photos up
If you can post here, you can select the 80 secton of Vehicle Classifieds and post there.
