How to fit smaller bore wheel (Vector 5) spare tire chain carrier?
Denver
Got around to swapping a matching 5th Icon Vector 5 onto LX570 w 285/75 R17 KO2. Issue is the chain carrier in spare tire location is just a hair too large to fit thru small bore on Vector 5. Any elegant fixes others have come up with, ideally reversible? Is it a pita to thread the chain back into the crank housing if I put in a screw close (locking) caribener on frame mounted side of the crank? Would detach chain from caribener, let run out free to spare tire side of crank. Any ideas appreciated
Check out the solutions for the rock warrior wheels, it may help if it is the same challenge.
Thanks, the RW search did the trick. The last post below seems to be best solution. Locking carabiner (quick link) and grind off an inch or so of the tube.
