BulletHead
Village Idiot
I need to cut a few shelving units endsd to reduce the height, the type you see in CVS. They are fabricated with about 1/8" steel. Would I need a plasma cutter or will an angle grinder do the trick?
do i need to get a special kind of wheel on the angle grinder? diamond tipped etc?
just to state the obvoius.....a hacksaw costs about 10$ might be just as cheap as a set of cutoff wheels. i hear those things aren't cheap.
when you say skil saw, do you mean a circular saw?
Circular saw is the way I would go.
go to Ace and buy PN 2079960
cut off blade for a circular saw
works good do it all the time. we keep the blades on hand
some times it is just the best solution.
I've been using this one for few years, maybe three or four. If I owned a metal fab business I'd get a Milwaukee, but for casual use the HF unit will work fine and last many years. I have cut steel up to 1/4" thick with it using cut off wheels. Since I got this the only thing I use a hack saw for is PVC sprinkler pipe.would $30-40 harbor freight angle grinders work?
Isn't it kind of hard on the saw?yes
I prefer the DeWalt blades (don't know who makes them for DeWalt). They seem to last longer than others I've tried, but they all get the job done.
In my shop at work I've got a plasma cutter, oxy/acet torch, jigsaw, sawzall, angle grinder, numerous die grinders/ cut off tools, porta band, etc. For cutting sheet weight steel I reach for the circular saw almost every time. It's faster and more accurate than any other method. I've even cut 1/2" plate with mine and even though you burn up blades quickly at that thickness, you get a perfect cut with no grinding.
