So I did the park brake adjustment line the video and it seemed easy enough. During the process I noticed that the passenger side star wheel adjustor was installed the opposite as the driver side. I didn't think that would make any difference other than you have to spin the adjuster wheel the other way to tighten it compared to what the FSM says. That how I figured out it was backwards.
I got it adjusted and it held on a hill but just barely. I didn't have time to mess with it any more and I drove it 140 miles home. I noticed that I could hear a rubbing sound on corners at 35/40 mph. When I got home, it would not hold the car on my steep drive way. I think the main issue is that I didn't quite get it set tight enough. The process, while simple isn't exactly precise. You tighten the adjustment until you cant rotate the hub then back off 6 to 8 "clicks" except there is no "click". You do this by feel as you cant hear or see anything as you do it.
Could the backwards adjustor be affecting something? Could that have anything to do with the rubbing in corners I hear? This is what I'm talking about:
it does thread on only one side but I think it still just pushes both pads the same.
Edit: the screwed end should face to the rear.
here's another good video should how to install the pads:
