I followed Dan's advice. It's straightforward and it worked for me.
Posts: 9,184 Does a lifted 80 really have caster issues?
Riley, this is how I did it:
After the lift is installed, park the vehicle on a flat surface.
Measure from the ground up to the center of the mounting bolt on the frame end (rear) of the leading arm. Then take a measurement from the ground to the center of the front axle housing mount bolt. Record both measurements. You will get something where the rear will be a couple inches higher than the front.
Remove the arms and lay one of them flat on it's side. get a long straight edge like a 4 foot level or mark a straight line on the floor.
Position the arm so the center of the front and rear bolt holes are the same distance from the line as they were from the ground.
Take a carpenter's square or the like and mark lines perpendicular to the straight edge, through the center lines of all three holes.
Mark the top and bottom of the mounting rings where the bushings go. Do all three and mark both sides of the arm. I used a cold chisel and "unch marked" the top and bottom. Be sure the marks are clear as you will be very unhappy if you can't see them later.
Repeat the process on the other arm.
measure the center-to-center of the axle mounting bushings, IIRC it's 7.25 inches.
Press the old axle mounting bushings out. Position the OME bushing in the front hole so that the bolt hole in the bushing is at the top mark and the line moulded in the bushing is pointed at the bottom mark. Press the front bushing.
Next you will postion the rear bushing so that the hole is at the bottom mark and the line is at the top mark. BEFORE you press the rear bushing, check the center-to-center measurement, you should be right on.
Repeat on the other arm and re-install.
