I am curious as to how often the owner's of 80's have to replace and/or turn their rotors? Let's hear your stories.![]()
. News flash, brakes work by converting energy into heat! Heat is a good thing, even smoking them, under controlled conditions is good for brakes. For best brake performance and life, the pads should never touch metal, the rotor should be covered with an even coating of pad material, so braking is pad material to pad material. This is done by smoking new pads several times. It is called bedding the brakes.... Let's hear your stories.![]()
Properly maintained rotors should last pretty much the life of the rig.
