In this instance (ofcourse it is not optimal) from either the hard line to the injector ,or under the return line, or maybe it was even a dodgy injector build between the injector housing and threaded top part of the nozzle housing (mid part of the injector housing between the 24mm and 27mm) (cheapest on ebay.au.) Wrong of me to blame him as the injector in question belongs to the port I damaged.
Fuel is not bubbling in the port and looks dry down there, so I believe the injector is well seated in the head port.
I have ordered some uv dye to try and pin point the leak, it must be tiny, and takes a few minutes to squeeze out a drip, but this builds after a bit of a drive. I am wary of over tightening.
It could be the injector hard line olive below the hollow nut with a hairline crack possibly. Probably next place to try with a spare.
I tried changing over the hard return line with a spare, so that rules that out.
Can the diesel run down the injector port, past the injector and seals and then run through precup into the cylinder? Surely a pool would form above the injector if it is holding pressure?
I can still climb a steep hill at 2000rpm in 3rd gear which I have always been happy about. It is not particularly smoky either, you have to look for the little smoke. Starts fine and happy too, just gets a bit wet in that one spot.
