Hey guys
Not sure when the horn stopped working, but it is not right now
Upgraded to Premium Horns and realized nothing happened. I know 3-4 months ago the stock horn worked.
- Relay replaced, no change
- Relay doesn’t click when pressing horn
- steady power to fuse and relay
- jumping the relay gets the horns to work
- steering wheel position doesn’t help (all way up, all way down, middle; all way right turn slowly going all way left turn)
- took the airbag/ horn cover off, no dirt, springs intact, all cables look fresh/ clean and connectors all connected
All that tells me three possible outcomes:
- clock spring bad
- any other ground issue
- didn’t check the contacts on the steering wheel properly
Any advice what to test/ make sure/ do before I dig into clock spring replacement?
Would be glad if you would tell exactly where to put a wire in as I’m an electrical noob
Edit:
No other electrical issue beside D light not working. But that’s not related to the steering wheel…
Airbag light off, cruise control working and lighting up,… everything else on the steering wheel works.
- clock spring bad
Edit:
