- Thread starter
- #21
Degnol said:"The shifter pivot i used the origonal stud and cut the pivot off. Drilled it out and used a 5/8s rod i had."
So what holds the 5/8" rod to the case? Did you drill and tap the case?
Very clean looking setup. Thanks for the post.
Ed
I used the stud that was sticking out of the case, it is basicly a bolt on one side to go into the tranny and a shaft coming out that the normal shifter pivots on, i cut the shaft off and drilled it out and welded my piece of 5/8 rod to it.
The problem I had was that with two independent shifters I used a 5/8 drill which was slightly to large for the shaft and it wobbled…nobody likes looses shifters running around. So I decided to just use a 5/8 steel rod I had in the scrap bin.
Stew
