HJ47 welcome here?
another three
next set. I had a couple more shots of the pto shaft finally painted up and installed, so I thought I'd post them.
The floor of the tub, along with the dash, will be getting another pass of epoxy primer tonight. Third and final pass of primer (to cover the cowling, rocker panels and the rear wall of the tub) will be the day after that, all being well, and then the bed liner can go on in a couple of stages.
Getting very close now with the cab sections. The main tub section has had 2 rounds of primer, and the third should happen this evening. In the 2nd and third photos you can see that the floor of the tub has been re-primed, covering over the seam sealer lines. When a single color is back on the metal, of course all the faults are that much more visible, which is frustrating because just as I think I'm almost there, a whole bunch of work is yet again required. I spent 8 hours sanding the tub sections yesterday.
I'm really looking forward to getting there tomorrow morning and seeing the tub all in blue primer. next step will be to mask off for spraying the floor of the cab with bed liner. One of the fenders still needs to be papered-up yet for the bed liner application as well.
