Are the new shoes OEM or aftermarket? if they are aftermarket they might not be as thick - that coupled with a out of spec drum might give you problems.
Is your e-brake tight? how many clicks does it click until it it as far as it can go?
I'd just replace the rear drums as you have already done everything else. Are the front rotors OEM? Make sure you replace the drums with OEM as well.
Not sure if anyone mentioned it - and you probably already know, but, if the brakes are spongy and ineffective on the first depress then get better as you pump them then you have air in the system. Although you have said you have bled them numerous times so there should be a problem.
If you use the e-brake while depressing the brake pedal does the braking get better?
Interesting.
Interesting.
