Well I'm back at trying to get the brake issues figured out on my 88HJ61. The issue I am having is less than optimal stopping power and a spongy brake pedal.
Here is what I have done over the past 6 months or so, all to no avail:
-Bled and Bled and Rebled the brakes (10 times at least over the past 6 months, see below). Bleeding has been done using both one man bleeder kits, and the two person process.
-Replaced the rear wheel cylinders
-Replaced the rear pads
-Checked the auto adjusters at the rear
-Checked the e-brake cable
-Adjusted the rear shoes manually through the inspection hole
-swapped out the m/c for the bigger toyota truck one (1" bore) (twice)
-swapped out the front calipers for the bigger toyota truck ones
-changed the shoes and pads
-replaced the front rotors
-turned the rear drums
-checked the system for leaks
-swapped back to original m/c and calipers
-bench bled the m/c each time it was replaced
-cleaned off the pads and shoes each time they were replaced
So needless to say I'm kind of at my wits end with this. Does anyone have ANY ideas? My current theory is that it is something at the rear.. I clamped off the rear brake line tonight and the brake pedal is super super tight when I do this.
-Maybe the drums are out of spec?
-Maybe the rear soft line needs replacing?
-Maybe the rear shoes aren't contacting the drums correctly?
My next step is to swap out the shoes and drums from a BJ60 I have sitting in the backyard. But any other theories are welcome at this point!!
Thanks..
Thanks..
