Hello Folks,
Fairly new to the community and yes I have read several archives on the maintenance but still need some help to stream line info for my Indy tech.
The vehicle in question is a '99 LX 470 with 170,00 trouble free miles
1)- AHC servicing; Lexus will not service the AHC
The fluid in the reservoir is on the low side. The ride is slightly stiff but the accumulator testing showed the fluid in the reservoir is still moving around 7-8 points.
Possible to get a set of instructions may be off FSM showing the flushing sequence?
Do I go ahead and change the springs (coil overs) to OME 6868 and also does OME stands for OEM or is it a company?
Do I change the front springs too and then adjust the TB?
Would the new springs/coil overs make the truck sits higher?
2)- Transmission/differential fluid replacement;
Possible to get a "how to" info may be from the FSM for my Indy?
3)- Drive shaft lubing:
I am going to take the yolk off and clean the splines and all that before paking with Molly grease but once again possible to get some instructions from a manual?
Appreciate all the help and thanks for being patient with me.
Later
Later
