- Thread starter
- #21
It is the same connector, it just slides on the center tab instead of the side terminal. If the pressure gauge is even with the line you should be good, if it’s way below then it is messed up.
A standard female spade will slide on the brass centre connector. That's whats on mine anyway.By what means does one connect to that center post? What connector or interface?
You must use the center, gold terminal, as I found out. You probably ruined the factory gauge as I did.
Female spade connector pushed on from the side.
Again please. Possible typos.Crimp on a standard size it the original is the half size spade
