High Beam Question
Georgia Tech/Alpharetta
Does anyone know how to make the highs beams come on without turning on the low beams during the day?
At the moment, when the low beams are off and i flick on the high beams, the low beams also come on.
I want to make it so that when the lows are off and i turn on the highs, only the highs come on.
Anyone?
Flashing HIDs is very very bad for them.....
I have wondered about this as well. Hows the lights pman?
Other than the bulb seating, they are great. The high beams are EPIC at night.
Oh, right, forgot about that. Why is that... forgot why but do recall knowing that with past 911s I have owned?
It's bad for the ballast cause of the high voltage it has generate. I'm not sure what t does to the bulbs, but it's bad for them too.
If I recall correctly, my LS430, with factory HIDs, behaves the same way... So it seems that Mr. Toyota deemed it ok at least in some circumstance.
Because of this, I have not worried about it at all with my LX either (I have aftermarket low beam HIDs.)
Since no one seems to know how to do this.
Does anyone have an EWD for a 2000 LX470?
Correct, I only want the highs to come on when I toggle them (assuming the lows are off). Hopefully i can do this without affect the low beams at night. I do not care about being able to reverse this once it is done, after what we did my headlights, Im stuck with HIDs......unless i spend $$$$$ to go back to stock
I have already disabled DRL by cuting one of the wires on the drivers side near your feet. I have also done the fog ligh/hi beam mode (the one in FAQ by sincity).
I thought my lights you used to function this way, as a result of the fog/light mod, but i guess i was wrong......or Lexus changed something when they opened my steering column up.....not sure cause the fog light mod still works.
