High Beam Indicator Light
arizona
My high beam indicator light on the dash stays on when the lights are set to auto, or off. When I manually turn on the headlights it is off. All the lights work as they should. I'm assuming it's an issue in the stock, but before I replace it entirely I though I'd check and see if anyone else has experienced and fixed this issue.
Thanks,
Jim
Replaced the switch, no dice. It acts the same.
Any ideas gentlemen?
Jim
For all of those that have been following this riveting thread. Turns out it was the DRL resistor going bad messing with the system ground.
Thanks,
Jim
