help with temp control adjustment
the switch will go all the way to the cold side but wont go past about midway back to the heat side. is it a cable that operates it and if so is it a universal part or oem only.. got nothing in my search
The push-pull cable that controls the water valve could have kinked. That's usually caused by corrosion on the metal cable creating so much friction that when you push the cable it buckles.
Remove the panel behind the control sliders and inspect the cables. If there's a kink, straighten it and spray some penetrating lube in the cable & work it back & forth to get it moving easily again
awesome, thanks for the quick reply sir.
