Help with Secondary Air Pump (P2445, P2433, P0171, P0174)
Chagrin Falls, Ohio
So last year a mouse decided to build a mansion of a nest in the V of my 2005 GX470's engine and soon after that the dreaded check engine light came on. Since then I personally have replaced the following:
  • secondary air injection pump
  • both left & right air injection check valves
  • air injection control valve
  • intake manifold gasket
  • PCV Valve
  • Vacuum Switching valve (located underneath the intake manifold)
  • air injection system hose
I have cleared the ECU of all codes and I still get the P2445, P2433, P0171 and P0174 trouble codes. What am I missing? I would rather fix it properly but if I have to I'll buy the SAIS Bypass.
Please and thank you for any advice!
did you ever get to the bottom of your p0171 code. I am experianceing this same issue. I didn't have a rodent living in my car. But still getting the code.
Replaced the MAF Gromet, PCV Valve, fuel filter.
Want to get this issue resolved thanks.
