I recently mounted a CB antenna on the front bumper of my 80. It's a 3' Wilson Flex 5/8 wave. Mount is just a generic plate-mount. There is a factory cable from the antenna to just forward of the firewall. I cut the factory end off of the coax coming from the radio and fed it through an rubber grommet on the firewall, then stripped and put a new end on it to join to the cable from the antenna.
On a run a few weeks ago a guy in our club hooked up an antenna tuner. We had to jury-rig some things to make the connection, but were convinced that the SWR was to high. So I went and got a Radio Shack CB SWR meter and checked it out tonight. SWR was way over 3?!!?
So I started checking things.
- No continuity from the antenna core/top of the antenna mount to chassis ground
- Good continuity from bottom of the mount & outer shell of connectors to chassis ground.
- No conductivity from inner conductor to outer shell
There is also a separate ground lead from the antenna - I tried screwing this down to its own hole as well. No significant change.
I had a spring between the mount and the antenna. I took that off and screwed the antenna directly to the mount. Again, no significant change.
Now I haven't actually played with the tunable tip on the antenna yet - ran out of daylight. But it's my understanding that this is for fine tuning and won't take you from well over 3 to something reasonable.
Any suggestions what else I should look at? Not the greatest picture, but you can see the antenna on the passenger side of the bumper.
FWIW, I got decent reception on that run, but didn't transmit much as I understand I could kill my radio trying to push power through a bad antenna.
