HELP WITH BRAKES (1 Viewer)
Charlotte, NC
One of my LC's loses brake fluid every now and then. The challenge is that I dont know from where. There are no fluid leaks visible. No droplets on the ground. No wet joins. No wet booster. No wet ABS. Not a drip anywhere. But drops enough for the light to go on every 3-4 weeks.
What the ?
you may want to check for leaks between the master cyl and where it attaches to the booster if no visible leaks elsewhere (unbolt master cyl and look in where the pushrod goes)
also, if raised and original lines have a good look at the body to diff lines
